07.23.2008, 03:32 PM
I did a Muggy already (made my own motor mount). It is a blast to drive and very fast (see my sig for build thread).
I am also working on an LST2 conversion. I didn't like the layout with the transmission; doesn't give you much room for batteries. I have seen a couple on here that have used an emaxx tranny to put it in the center with batts down either side. This looks like a better layout to me, but may require a custom upper deck. I had an extra center diff for the Muggy and will be using that along with front and rear Muggy diffs (closer to truggy ratio than LST2 diffs). I will likely do custom top and bottom chassis plates (maybe CF).
