gogglespaesano
gogglespaesano's Avatar
07.23.2008, 10:21 PM
I converted an aftershock to brushless. I am using the FD motor mounts, however, I will never deal with them ever again. They sent me two different sized mounts, wouldn't return phone calls or email, so I've had to make a shim using some cardboard to run the mounts, and there is no way to adjust for using different sized pinions, even if you have the same sized mounts.
If you can, wait for the mount that Chapito talked about. I've dealt with "The Dude", running his single speed spur adapter and pinion mount, top quality work and great customer service. If chapito's links don't work go to hdrcvideos.com and look under the custom conversion project area section, same site, lstforums, but that's an old link chapito put up.
