Thread: Neu 1509
07.23.2008, 11:19 PM
Originally Posted by BlackedOutREVO View Post
My chassis is 14mm longer then Mikes chassis lol... I will probably run the same tires
I will be running a modded R1PRO, with 3s lipo. How should I gear the motor? I want 40-45 mph, but running cool
Depends on the kv you buy. On 3s you want something like 3000 or up. If you go around 40k rpm max and gear with a 14t spur, that should get you around the desired speed...
