07.24.2008, 01:31 AM
The 36mm tekno mount I have has the 4 m4 thread holes placed in a square pattern, 34mm apart on both sides. If the slots for the nitro mount line up with those specs, then you should be able to use it. Problem is that it will sit too far back from the spur, unless you use the tekno clutch adapter and a clutch setup to make up the space.
