lutach
lutach's Avatar
07.25.2008, 01:58 AM
Thanks Luciano...
Looking at the rotor, it has 12 flats on it that can be felt thru the kevlar wrap. Does that mean it is a 6 pole motor? Or am I missing something: reasonong is that a magnet has 2 poles, and 12 divided by 2 would be 6?
If it is a 6 pole motor, should I run higher timing? Would that improve performance?
That rotor looks just like the one in my Extreme. They might use 2 magnets per pole. Funny thing you asked about timing. The 6S controller that I've been testing was acting up when I had low timing running the Aveox. When I went to mid timing the controller worked perfect. Now days I'm getting more and more confusing as some companies say to run low timing to keep temps down. I always go mid or 5 degrees of timing for 4 pole motors and high or 10+ degrees for 6 pole motors. My 60A controller burned when I changed timing on it when I was running the Mega ACn16/15/1. I had 15 degrees of timing and it was doing awesome, but I made a mistake and changed the timing instead of another setting and a couple of FETs went dead.
