gearing question
dpb318
gearing question - 07.25.2008, 05:57 PM
im running 4s with a 9xl with a 20t pinion and a 49t spur, the esc is 118 degrees, the battery is 108 degrees and the motor is about 160. to lower the temp on the motor would i put a pinion with more teeth and a spur with fewer teeth? or is it the other way around
or is 160 for the motor fine in the first place
thanks
