83gt
07.26.2008, 01:18 PM
Originally Posted by Matthew_Armeni View Post
I run a 1300kv 60mm Medusa in my Losi 8T on 6s through a MM. I run the Tekno conversion with clutch and mechanical brakes. The motor is plenty to pull the truggy around, especially if you are racing it.
That's good to hear. I've been advised several times against the 60mm medusa for a 1/8th truggy. You have no problems with heat ? It's really amazing what those little MM controllers will do. They hang with some of the "best" ESC's out there. I smoked a couple quark 125's and an MGM160 and the MM just kept right on.
