GriffinRU
07.27.2008, 07:41 AM
Artur,
Should I be expecting a similar occurance with my EEC?
So far everything is still looking great. Just wondering if there is anything you see that would make you think I might have the same result.
Hi Jeff,
While I am in the woods, in terms of what happen to Mike's ESC, I would recommend to pop the top cover and apply couple drops of 5-minute epoxy on all three sides in-between ESC pcb's and enclosure. This will reinforce pcb's assembly position within enclosure. Entire pcb assembly can be moved inside if you pull hard by wires or by vibration, original plastic cover has support ribs to hold pcb's in-place, ours proto-runs didn't.
Or you can send it to me and I will check it out, yours was modified slightly different.
