brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
07.27.2008, 01:33 PM
Could you not just put the motor in a vice (light pressure, with rubber or rag around it to protect it), hook up the ESC and battery and have it spin the shaft slowly (1/4 throttle or so) and use a file to grind it down a bit until you can get a 5mm pinion on easily? That would be how I would do it, except I don't have any 5mm pinions.
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
