I was never planning on running 6s in the buggy... the 6s battery was for the Revo.
I already have a MM ESC on the way as well as some Badlands tires and a couple other items. After hearing about riceman and Matthew_Armeni having great success with running 6s on the MM ESC, I think I will go with a 5s battery. Hopefully everything will be ok with the MM if I run 5s on it and nothing smokes. So sometime at the beginning of August, I'll order the rest of the stuff like the battery, body, gear(s), and UBEC.
I'll keep you all updated.
