the stamping on the individual cells reads 3.7v 4700.....now is the 4700 the mah's?....if it is then how was the pack a 3s2p 8000mah pack?....if it had 6 3.7v cells at 4700mah's?.....and by the way Arkt1k....i connected the cells is this configuration:
Attachment 5138
now, my hyperion charger only charges up to 5000mah....and if this wiring is correct, then my charger settings should work if i set it up to charge a 2cell lipo at 5000mah.....right?
