07.28.2008, 01:09 AM
Originally Posted by GriffinRU View Post
It is great motor and I still have bad fellings towards Serum he compared this motor with 7XL!!!!!!!
This is the best motor you can get from Germany, even Lehner is nothing to compare.
At the time Sculze was the only one ESC which can handle this motor, but now MGM can do great and I hope MMM and MM with 1.17 software.
You cannot bring feigao to the level of Plett, even if you gold plated it!!!!
Balancing is very important and plett is the best in that area. I had plett's , lehner, feigao 1-4, nemesis, mega, medusa, kontronic, align, axi, aveox ... and none of them can even get close to plett.
It is not advertisement, it is pure facts, if you have budget than plettenberg is the motor for you.
BUT YOU NEED TO KNOW HOW TO UTILIZE 4-6 POLE MOTOR it is not the same as 2-pole and BrinG calculator doesn't work great here either, not that Brian is wrong, it is very unique motor case.
GO PLETTENBERG, all the rest is HYPE - 'TRUE HYPE" not by Patrick
Good info Artur. I have had alot of success running my plett motors with quark escs. I will try your mod1 MM with the maxx w/fan on 4s. It is doing fine with the quark 125b, but I prefer the programability of the MM and the lvc settings.
What would you suggest I set the timing at on the MM for the plett? I am guessing that higher timing will be better. Patrick mentioned that the MM auto figures the timing, and the adjustment is in that range, not from a baseline setting. If that is the case, normal timing should work for the plett? Or should I go higher?
