rchippie
rchippie's Avatar
07.29.2008, 08:33 PM
Does anyone know how to remove the pins in the ends of dogbones?
I have all the tools you can imagine even an 11 ton press but i cant figure out how to go about it
when i rebuilt my lst2 cvd's . i had to use a bearing press . I had a steel plate with a hole just bigger than the pin drilled in it . then i pushed it as far as it would go . then i had a friend take needle nose pliers to hold the other pin . Then i pressed it in untill the other pin fell out . then i centered the new pin .
REAL MEN RUN BRUSHLESS
