azjc
07.30.2008, 02:51 AM
I've charge my both pack in same time tonight, and i've remark than during charging, on the chanel 2, the current display is realy not stable. Mycurrent was set to 2.5A, and the display always swing between 2.41 to 2.53.
On the chanel 1, the current display is realy more stable, play between 2.49 to 2.51.
And another proble, when the charging process is ended, and the display show "CC/CV END", on the chanel 2, the current show 0.00A, but on chanel 1, the current show 0.62A, and the charge was ended
Could you tell me if you experiment the same thing on your's please??
Thank you
I have the single 0610i charger it will do both of those things you mentioned as being potential problems...the listed current will move around a bit, the charger will turn it self off for a split second to check it self it will do this several times durin a charge, and when the charge ends sometimes it will show a small amount of current
