azjc
07.30.2008, 05:25 PM
Originally Posted by yuri View Post
Again... Went thru the pack stopping every 4 minutes cos the esc likes to come up to 75C (167F), don't know if it will be better with the 1500 one when it arrives... Any ideas?
Amb 30C (85F)
Battery 34C (90F)
Motor 80C (175F)
the higher KV motor(2000) will pull more amps (increased heat), so in theory it will run cooler by going to the lower KV motor and should enable you to run more WOT which is better for you ESC. You will pull the most amps punching from a stop
