07.30.2008, 09:00 PM
SHIM YOUR DIFFS
I have a stock diff in the front and ball diff in the rear and that holds up to my Neu fine. Thetoyz is coming out with steel diff gears soon if shimming them doesn't work. Do you have Duratrax Steel cvds?
EDIT: I think the diff gears are out, but out of stock. The restock date is 5.30.08, so I don't know when they will be back in stock.
