david lamontagn
08.01.2008, 08:33 AM
OK somes news on the MGM brake.
The brake on this controller is a piece of scrape
I'am not able to have a linear braking. Some times, when i touch the brake just a little bit, the controller lock the wheel immediatly and the back of my truck raise in the air and fall on it's lid, and other time, when i touch the brake, the controller start to give full trottle
The rest of the controller run very good, it's smooth, it run cool, but the brake is a dump
I've try to upgrade to the 3.23 software, but the controller seam to not want to load it, i've try twice to download it, and both time, the download process was succesfull, but when i connect the controller to change somes parameters, the version is still the 3.21. I've try to run an autotuning, but don't change anything.
As soon as the MMM v2 will be in stock, i'll buy it for sure.
I can't understand why a $300.00 ++ controller can't have a progresive brake in it. And i can't understand why it give trottle when i touching brake. I've try to reinitialise the end point on it (full trottle, wait for 3 bips, full brake wait for 1 bip and neutral wait for 2 bips), but nothing to do.
I don't know if you can immagine, but when i run at WOT, and i try to give a little brake, and the controller decided to lock the rotor..... ouch!!!!1 the drive train
And on other side, when i'am near an obstacle and i want to brake and the controller give full trottle, same thing, ouch!! the front a-arm
