standard_63
standard_63's Avatar
10.13.2005, 09:48 AM
Originally posted by MetalMan
That sucks! Do you have carpet in your livingroom? I'll bet that the front tires got a lot of traction which put a lot of strain on the BEC. And the higher the voltage being put into the BEC, the more heat that will have to be released. So, the chip could have gotten hot enough to start a fire! The BEC is easily rated to handle a steering servo when the car is actually moving, but I have a feeling that you might have been doing a lot of turning in your livingroom.
Yeah, you're probably right. Also the steering is a little tight on the SM as it is so I suppose I just overworked it. The thing is though I was checking for heat on the servo and ESC almost constantly, and it never got very warm at all, just suddenly POOF!!
So, in the future would receiver pack or UBEC have eliminated this from happening? I'm willing to try one more time to get this thing running, and will bypass BEC if that will make it more robust. I might try it again tonight with a receiver pack and see if it still works, maybe I only fried the BEC part? (hopefull, but would be nice)
So far I'm not so impressed with the way the MGM runs -- sometimes pauses, doesn't always freewheel, and reverse goes on suddenly sometimes when I only mean to hit the brakes. It's not sealed up too well either. So I'm thinking of getting one of the 120A micro BK controllers instead, or even a Future 18.129 -- gasp! I know the Schulzes sometimes aren't popular but I have an older 58ce on my stadium truck that just rocks. So far my favorite controller, and I know many people like the UF75. I dunno, pretty confused and discouraged at this point, it may be awhile before I buy anything.
Thanks for listening/reading!
--Jonathan
