08.01.2008, 09:48 AM
You can run 6s i.e. 2 x 3s packs in series - 1515 2.5DF would be ok but you may want to look for a lower KV motor 1515/1.5Y 1500KV.
Ideally you would want to look for a set of Enerland 3s 5000mah packs (polyquest, flightpower, neu 25c/30c) - You can velcro /tape them together for 6s.
You could then use a parrallel adapter to charge them as a 3s 10000mah pack. I'm guess this will take a few hours on your charger.
