MetalMan
MetalMan's Avatar
10.13.2005, 06:50 PM
If you are going to run 14cells, try a 11t pinion (if you could find one). Otherwise, you will have to find out if a 12t will make the motor get too hot, and if it does, you would have to go down to a 10t pinion. With 16 cells (TOO MUCH, IMO) the 10t pinion might be too big.
