B4maz
08.02.2008, 11:43 PM
Thanks, E-Traxxer.
Anyone know where to get a suspension spring coupler? I tried searching, but don't think I'm using the right terminology. The rear-end of this car is too soft even after dialing in max preload - especially after installing Revo springs in the front. But I don't know of a stiff-enough spring I could use there. So, I thought I'd use the stock rear spring along with the stock front spring stacked together, but I need something that will keep them inline. I hope I explained that well enough.
How much does the car weigh Brian? Mine is about 9lbs ready to run and I was able to get the rear arms slightly above level with stock springs. I played around with the mounting positions.
