Originally Posted by raptor50
BIG Problem.
The batt. mount wont fit into the diff bearing. Any ideas? I have been tinkering with this for about 30min. and gave up.
Do you mean the diff bearing is tight in the mount itself(as the picture indicates)? This shouldn't be the case, but if the bearing hole is too tight, send it back to me and I will fix it or replace it immediately. The holes are a pretty tight tolerance, so if the bearing is mis aligned even a little bit, it won't budge without a lot of effort. I have seen some tight ones here and there, but I try to fix 'em as I find 'em to make your life easier(the tight ones still work, but require some muscle and precision when installing).
For the battery box, simply place the battery into the desired position and attach it through existing OR new chassis holes. I usually start with existing holes to get the box in place. If more holding power is needed, then it is easy enough to add a couple holes. :)
