08.03.2008, 10:42 PM
No you CANNOT put all three rails in series - they all share a common ground.
Hmm, I thought the mod was fairly straight forward. The diodes are just to drop ~1.4v (0.7v each) so the sense wire sees less voltage than there actually is. So, it causes the regulator circuit to boost the output voltage until there is ~12v on the sense wire. This causes the real output to be ~1.4v higher than that, or ~13.4v.
I could have used simple resistors as a voltage divider to do the same thing, but preferred the diodes method.
Think of the sense wire as the feedback pin on a regular linear voltage regulator, or the - pin of an op-amp. Same basic thing.
