Originally Posted by Sneaky Pete
I just realized something...I'm used to the Traxxas style ESC's which turn off once you unplug the battery and then you have to push the button again to turn it back on once you plug the battery back in...
Are you sure it actually stops ALL current draw? The switch on most ESCs simply disables it, but the circuits still draw a little current (probably well under 1A), which is a good way to deep discharge your batteries if left plugged in for a while...
