kevin23
08.04.2008, 09:23 PM
fahrenheit,running the truck real hard,lots of hard accel through a relatively small clay offroad track(120'x80').
most all the turns are pretty tight,really pulls the power out of the batt's and creates heat.
I ran the rc pro race at a different track that is larger with a little higher overall speed and the motor temp was 20 degrees cooler after the main last week to this week's race.
I guess it depends on how you are running the truck,I do think that a 22 is going to be the highest you should run with this setup,imo
