08.04.2008, 09:35 PM
Got my MMM today. Uninstalled the MM and mounted the MMM. Hooked it up to the Castle Link and set it to what I had the MM set to. Took it out side and ran it up and down the street where it ran great for about 4 minutes and then stopped .... just like the v1. I immediately unplugged everything and took it inside. I put it on my work station and plugged the battery back in and switched it on. It seem to come alive (unlike my MMMv1) but any throttle gave it uncontrolable cogging ... I unhooked everything again.
Now, what is really strange is that when my MMMv1 died on me and I found it was going to be awhile before I'd get it back, I re-installed my MM. After installing the old trustee MM I experienced the same severe cogging. After checking everything out I determined that it was the Neu 1512 1.5 that was the problem component. Since it was still under warranty I sent it back to Neu where they prompty sent me a replacement. I installed the new Neu with my MM and everything ran fine until today. I ran my Jammin just yesterday with the MM and Neu and it ran fine. Now I'm wondering if the MMMv1 caused the problem in the Neu ... I mean this is one hell of a coinencidence. I'm not sure where to go from here, I have another 1512 never used and of course I stll have my MM. I think I'll uninstall the MMM and install the MM and see what happens. I'll be calling CC in the morning and see if they can shed any light on the subject matter.
Just for the record, I was using a 4s 3700, and am not using a/the BEC. I'm running a short RX extension cable with the red wire cut so the MMM has not been modified. Also keep in mind this setup was running flawlessly for over a month with the MM and ran perfectly for about 4 minutes with the MMMv2 so if there was a wiring problem it would of never of ran. I'll report back tomorrow after I talk to Cc and try a swap out of either the Neu or the MMM.---------------------------------------------------------------
Jammin X1CR, Neu 1512/1.5D, MMM/MM, NO BEC
XTM/XT2, Nemesis XL, Hydra120, NO BEC
2 FireFox 4s 3700, 2 Neu 4s 5000
