wevie
08.05.2008, 01:20 AM
After checking things out thoroughly today:
1.) He is due for new wheel bearings. They are not smooth, but they are not shot, either.
2.) Unable to locate any physical drags, I plugged the MM into the 'puter and it came up with a setup error. It said Punch Control Out of Range. ??!!?? I don't understand how that could be. I'm the ONLY one that has the ability to plug the MM in and change settings and I doubt if it would be possible to get the Punch Control out of range by just fooling around with the ESC.
Anyway, after resetting the parameters, he ran two Tenergy packs today without any heat issues.
Thanks for the help!!
