Thread
pinion vs spur teeth
5
Sammus
08.05.2008, 04:06 AM
pinions and spurs give whats called a gear ratio. if you want to compare different gearing, compare the ratio, same number of teeth on spur is definitely not the same as the same number on the pinion.
Sammus
Find all posts by Sammus
