10.16.2005, 05:10 AM
One thing you need to know about the FLM chassis, is that it has got a higher CG than the gmaxx. The batteries are a rough 3.5 cm higher, but for a basher, this would be just nice.
the stock motorplate is able to hold the BL motor, but i would make a brace, that holds the motor.
The savage diffs don't fit the 1/8th conversion, because of the larger ringgear. (too large in diameter)
