Thread: Aussie CRT X2
ffactory666
08.07.2008, 05:45 PM
Originally Posted by Fast5sRevo88 View Post
How did u mount the Tekno motor mount ffactory? I have an x1 i would like to have one of those on it.
You have to make 4 countersunk slots in the chassis for the mount and to allow gear mesh adjustment.
I just measured up drilled two holes ( make sure they are the right size for the screws ) were each slot starts and ends and then completed the slot with a dremel milling bit
Of course then i used a countersink bit . Dont forget though if using this mount you have to brace you centre diff somehow like i did .
