Trick440
08.07.2008, 05:51 PM
Originally Posted by azjc View Post
this is in the Revo forum....is it safe to assume its a Revo...could you supply more info about your setup?
Just Revo 2.5 conversion,
locked into 2nd, Std transmission gears.
Revo center diff.
Motor brake
Single steering servo
Quark 125b
Neu 1512 2.5d
17/54 gearing
Flightpower 4500, 30c
That should be the basics.
I will order a larger 19 tooth pinion. Should I pickup one more? If so what size?
Thanks.
