Thread: My crt.5
GO-RIDE.com
08.07.2008, 07:36 PM
yes 2s is correct! Medusa 36-50-4800 with stock tires I run 46/19 and with 1/10 scale slash tires 46/15 gearing. Speeds are in the mid to upper 30's and everything stays cool
That's the combo I was thinking of running, but the batts I have are Maxamp 2S 4200. They are only rated to 84 amps and the motor is rated at 97 amps. I'm not sure how that will work out?
I was also thinking of new batts 3S and the 36-50-3300 motor to get pretty much the same max rpm, but with less amps.
E-8ight - Tekin RX8 2000kv/4S
