Thread: Aussie CRT X2
ffactory666
08.08.2008, 02:04 AM
Got a little present from Mike today
Needless to say i can now confirm for you guys that the CR buggy mount fits the X2
Just need to take the dremmel and put a notch in it were it sits on the center chassis brace for clearance .
You can see it in the pic .
Also Mikes mount is about 1mm taller than the stock diff mount so you just have to shim the top of the stock mount so the top diff plate sits square . Bearing carrier is spot on .
Now i have gotten rid of the centre diff braces i had to use on the Tekno mount, a lot cleaner looking
Also received my custom one piece battery trays , perfect .
They clear the diff nicely , sit on the mudguard spot on and best of all i can now use my Zippy packs along with the enerland cells .
After speaking to Jeff i also got the front wall of the tray machined thicker for those hard lawn dart accidents
ID:	5211   Click image for larger version
ID:	5212   Click image for larger version
