Thread: Aussie CRT X2
ffactory666
08.08.2008, 03:38 AM
Looks great! Keep us updated on how it runs. Does the spur gear go wider than the motor mount? Thats what it looks like in the picture... I just noticed it because usually his motor mounts are just a touch wider than the spur gear, so that the battery tray can be as close as possible and it looks like you have quite a bit of extra room to push the battery a little closer toward the center.
Just checked for you .
Looks like the spur is borderline with the end of mount .
That pic does make the tray look like it's got a mile between it and the spur , just measured it has 3mm clearance. I could move it over a touch more , within 1mm of the spur but don't want to in case of an accident , wouldn't want that spur anywere near the lipo .
How much clearance do you have between tray and spur ?
