ReV:-O
RC-Monster Carbon Fibre
08.08.2008, 05:52 PM
thanks for all ur superb replys, i feel i am begining to learn... lol
Originally Posted by Finnster View Post
out of curiosity, how much were you quoted for the big MA pack?
As already said, the "C" rating can be real BS at times depending on the company as there are no real stds. They are not necc lying, but they may be "optimistic."
The only way to really tell is to see discharge graphs and compare performance, as well as anecdotal reports. If a battery is getting hot during use, its pushed too hard.
If you want 60 mph out of a Muggy, then you are going to need a lot of power. I would plan on 2500-3000W peak or so. For 6S, this means about 120-150A peak. If a batt truely does 125A continous you will be fine. However, 3000W out a 1515 is going to start pushing the motor perhaps, esp on a hot wind like a 1Y. If you don't already have the motor, I may think about a 1521 even so you don't possibly overheat and/or use thegreater TQ to gear up and hit your spd goal. 60mph in a big MT is really really fast.
the guy at maxamps quoted me $550 for the pack - which i am now not getting
heres a 62mph revo: http://www.youtube.com/watch?v=85v85Pn3DMk
ok, going by your advice i've made a new list of batteries
(i found all of these lipos at http://www.rclipos.com/RCL.html)
1:
Elite EL6S-5300 Li-Poly Battery In Stock $306.00
22.2V 5300mAh (6 cells) 30C/50C
Rating: 30C (159.0A) continuous, 50C (265.0A) burst
Dimension: 188mm x 46mm x 42mm
Weight: 800 grams
Termination: 10AWG wire leads
Request PQ / HP, AL or TP taps during checkout
2:
Poly RC PQ-6000XP-6S Li-Poly Battery In Stock $388.63
22.2V 6000mAh (6 cells) 25C/50C
Rating: 25C (150.0A) continuous, 50C (300.0A) burst Dimension: 165mm x 46mm x 64mm
Weight: 886 grams
Termination: Wire & PolyQuest/Hyperion tap
3:
http://www.impaktrc.com/product_info...oducts_id=2847
4:
PolyRC 6000 MAh 6S 22.2volt 25C pack
Cell Count: 6S - 22.2 volts.
Capacity: 6000mah
Pack Plug: None (You will need to add your own connector)
Tap Style: PolyQuest Style
High Performance Lipo pack
5:
PQ-5000XP 6S1P
Capacity : 5000mAh
Cell Model: PF 8643150XP
Voltage : 22.2V
Charge Current(2C) : 10.0A
Continous Dis.(25C) : 125.0A
Dimension(mm) : 54.0 * 46.5 * 166.5
Weight : 750g
6:
Thunder Power RC eXtreme 9000mAh 22.2V 6 Cell Li Poly 6s 9000 Lithium Polymer Battery
http://www.rctoys.com/rc-toys-and-pa...Y-BATTERY.html
7:
Thunder Power TP9000-6S2P Li-Poly Battery In Stock $599.99
22.2V 9000mAh (charge as 6 cells) eXtreme Series
Rating: 20C (180A) continuous, 50C (450A) burst
Dimension: 195mm x 48mm x 73mm
Weight: 1332 grams
Termination: Wire & Thunder Power taps
i particually like numbers 6 and 7 (i think they are the same) but i would have to buy a specific charger and balancer for the battery, as they seem to use their own brand. are thunder power related to thunder tiger, because i heard they wernt so great...
