08.09.2008, 10:43 PM
You are correct. The progressive-rate springs should also (depending on the rate) keep the truck from bottoming out like the hard springs do. Since they are softer to start you'll have better control on (relatively) smooth surfaces since the suspension can respond more quickly.
