jnev
jnev's Avatar
08.10.2008, 01:06 AM
^^^ Check where the motor leads exit the can on the rear endbell. The enamel has probably worn off the wires and they are hitting the metal can.
Looking closely at it, the enamel has actually worn out, and it appears that the windings are touching the motor can. This will cause it to short, correct?
Originally Posted by aqwut View Post
is the magnet/shaft bent?.. Lehner just sent me a brand new 2280 .. similar thing happened to mine.. one of the windings came a bit loose and rubbed against the magnet.... Is your rotor shiny/silver.. or does it have black spots on it.. if it has black spots, then it definately was rubbing against the stator...
The magnet/shaft spins perfectly straight and for a very long time in the bearings. But I did notice that on the magnet, there are black stripes on only one side of it. It is about 1/3 of the circumference of the whole magnet going up to the top and bottom of the magnet. So that probably means that not just one strand was sticking out, but pretty much the whole side.
My brother is coming back from vacation tomorrow with my camera so I'll get a close up shot by tomorrow evening probably. Thanks so much for the help so far guys. Really appreciate it.
