08.10.2008, 01:59 PM
I have destroyed the pinion bearings before. The possible wobble that bad bearings could cause may have also damaged the UV joint. I can imagine that some dry graphite lube might be good around the pins in the UV joints. I have seen the plastic stretch around the pin holes after heavy use. I will say that I have had better success with stock sliders than any cvds that I have tried.
