Originally Posted by mk351e
I am not new to spektrum - I've been using this remote for a couple of years. all settings were set to zero on the remote, except throttle endpoint, which was at 115%. the mystery pop happened during calibration - batts were plugged in and switch on.
Why do you have the throttle endpoint at 115%?
The only way my Spektrum radios calibrate properly with any of my CC ESCs is if the throttle endpoint is at 100%.
I don't know if that could be related to the failure, but it could explain your calibration issue.
Good luck tomorrow with your call. I hope you're able to figure it out and get up and running quickly.
