bl-is-future
bl-is-future's Avatar
08.11.2008, 09:53 AM
What motor for my savvy? Neu 1515 2.5D
Can't you brake with the motor when using the 2-speed??Yes
I'm going to use the orginal braking system but do i need to shut down the brake??Yes
And if i lock the transmission into 2nd gear then i can brake, right?Yes
And how to lock it into 2nd gear...JB weld the 2nd gear clutch to the gear and remove all gears like 1st that are not needed.
