08.11.2008, 11:58 AM
argh this is so confusing. i wanted to get a thunder power lipo but then i would have to buy their charger and balancer and it would all work out too expensive. i just want to buy the hypereion Net charger cos it seems like the best one.
Ive got a final list of batteries and they are all pretty much the same - just different makes and i have no ideas which ones are better:
1:
Elite EL6S-5300 Li-Poly Battery
22.2V 5300mAh (6 cells) 30C/50C
Rating: 30C (159.0A) continuous, 50C (265.0A) burst
Dimension: 188mm x 46mm x 42mm
Weight: 800 grams
Termination: 10AWG wire leads
Request PQ / HP, AL or TP taps during checkout
2:
Poly RC PQ-6000XP-6S Li-Poly Battery
22.2V 6000mAh (6 cells) 25C/50C
Rating: 25C (150.0A) continuous, 50C (300.0A) burst Dimension: 165mm x 46mm x 64mm
Weight: 886 grams
Termination: Wire & PolyQuest/Hyperion tap
3:
PolyQuest XQ LiPo Battery (6s1p, 22.2v, 4500mah, 30C, no cnctr)
Weight: 722 g / 25.47 oz
Capacity: 4500 mAh
Voltage: 22.2V
Dimensions: 168.5 x 51.5 x 50.5 mm / 6.63 x 2.03 x 1.99 in
Connector Type: Bare Wire Leads
with Multi-Tap Connector
4:
PolyRC 6000 MAh 6S 22.2volt 25C pack
Dimensions 168 x 48 x 67mm
Weight 926 gms
Factory C Rate 25C - (150 amps) continuous
Burst C Rate 40C - (240 amps) under 10 seconds
Ideal C Rate 21C - (127 amps)
5:
PQ-5000XP 6S1P
Capacity : 5000mAh
Cell Model: PF 8643150XP
Voltage : 22.2V
Charge Current(2C) : 10.0A
Continous Dis.(25C) : 125.0A
Dimension(mm) : 54.0 * 46.5 * 166.5
Weight : 750g
6:
FLIGHTPOWER EVO25-4900 6S BRICK
25C 122.5A CONTINUOUS, 50C 245 AMP BURSTS
DIMMENSIONS: 140MM/44MM/63MM
7:
FLIGHTPOWER EVO25-5000 6S BRICK
FLIGHTPOWER EVO25-5000 6S 21.1V 25C 125A CONTINUOUS, 50C 250 AMP BURSTS DIMMENSIONS: 54MM/44MM/166MM
8:
FLIGHTPOWER EVO30-4500 6S
30C 135A CONTINUOUS, 60C 270AMP BURSTS:
DIMMENSIONS: 165.0MM/44.1MM/49.1MM
im so confuzzled!
