Originally Posted by bustitup
so learn me something here...does that mean with that setting that when you use up 18.6 volts on the batteries which is 22.1 volts, that the system will shut down?
You start with 22 volts in your battery, as you use it voltage decrease, once you reach the voltage limit (18.6 volts) the power cut off
Just for fun this is a missed movie, My Mamba max cut off right in front of the camera :). (Download might be very slow overseas)
http://dl.free.fr/mTtQ6yfy9
