GriffinRU
08.11.2008, 09:54 PM
From what I can tell from most motor manufacturers, they seem to rate it using the following procedure:
1: Get the max continuous rpm. The 1515 is good for 60k rpm.
2: Get the motor kv. The 1515/1y kv is 2200.
3: Get the working voltage using the max rpm (step 1) and motor kv (step 2). 60,000 / 2200 = 27.27v.
4: Get the motors max continuous power rating. The 1515 is rated 1500w IIRC.
5: Figure out the max continuous current using the working voltage (step 3) and max power (step 4): 1500w / 27.27v = 55A.
Don't forget, this is a continuous rating. Depending on a lot of factors, the current can be more or less. No matter what, the motor will pull at least twice that value for initial bursts (starts and accleration), and pull less than that to maintain speed.
I will disagree,
Maximum current is at stand still or lowest RPM not at max RPM. You will never see 55A at 60000RPM with 1515/1y running at 27V.
Maximum current for Neu 1515/1y is 110A
Running current with rated load should be around 40-55Amps.
Better picture can be obtained from motorcalc or my program.
I can publish rated current for all motors if required.
