08.11.2008, 11:08 PM
I run a 1512 2.5d in my buggy,on 5s with a 16v cutoff,running hard on my local track I get 20min's.low start power,50% punch control,lowest timing motor temps 160,mm 110,batt's come off 120 degrees F.thunder power 25c 5000mah.Also with the throttle endpoint turned down to 75% as the buggy is to fast for me on the track.
I tried it on 4s 25c 5000 tp pack,had to turn endpoint back up to 100%,cutoff to 12.5v again get 20min runtime same gearing for both 13-48.
I am also running this in an 8ight.
