Originally Posted by BrianG
lol, two ways of saying similar things and each not knowing what the other is trying to say.
Just want to make sure that motor is rated by voltage, current and power. You can get the same power playing with volts and amps across efficiency curve, but you cannot exceed rated current. That is what I was trying to point out.
And numbers are not meaningless they just hard to interpret with out testing or knowledge of what to expect.
My program plots motor curves at full load.
