08.12.2008, 05:51 PM
So Patrick do I need to mod my new MMM V2 to keep the fan wire from being cut by whatever.
No, not ordinarily- feel free to pop open the esc case to check the wires arent being pinched- no biggie, and a simple mod to do with a dremel to create a little clearance in the esc case- dont touch the PCB though.
So should I set my endpoints with a a Spektrum dx2.0 at 100% with the MMM V2?And what happens if you dont.
Yes. if you dont, the esc will be looking for 100% throttle, but wont see it since the radio is set to 120%. I had the same issue with my lazer 6 radio and hvmaxx system; the esc wouldnt 'see' 100% throttle during programming until I dialled down the EPA setting a touch.
