08.12.2008, 10:13 PM
OK guys, take it easy.
coolrunnings: What did you use to get those current readings? I've tested a Hitec HS-5945MG (180oz-in @ 6v) and it pulled 2.4A under typical steering load. I wonder if the meter (or whatever) you used had a sampling rate too slow to capture the current peaks?
