bl-is-future
bl-is-future's Avatar
08.14.2008, 03:14 PM
well they wont max the 610net out but it will be it close. And to be honest to run the charger at it full potential you would have to have a 6s 9900mah battery. That would be a 12s 19800mah battery to max both out. all i have to say is WOW. the 23 amp for one charger should be all you need on a 610NET that should only limit you to 6s 7000-75000mah or so. the lower the s the higher the mah can be though so keep that in mind as well.
