08.14.2008, 09:29 PM
Are you sure the cell voltage was at that level? According to some of the user reviews on hobbycity, the balancer wires are kinda suspect. Maybe you just had a poor connection on a balance wire/connector? Or maybe the balance connector was dirty. Either way, a little v drop due to bad/dirty connection can skew readings.
I think there is an LVC device that monitors each cell while running, but it would be a PITA because of the added wiring IMO. How about increasing the LVC a bit? That way, even if one cells gets lower, the chances of it getting that low are less likely.
Another thing: I'm wondering why you had cogging? Unless you are geared too high, that shouldn't be a problem, especially with slotless motors.
