Sammus
Sammus's Avatar
08.15.2008, 04:05 AM
Originally Posted by TDC57 View Post
I’ll also try a lighter sway bar and maybe some suspension adjustments..
You want to soften the rear end or stiffen the front to reduce oversteer (ie car swapping ends). I can't see a rear bar on there, so if your going to adjust the front bar make it harder, not softer.
Also I dont think its adjustable on those cars without aftermarket mods, but toe in at the back will help you a lot to track straight under power.
